Old 02-14-2005, 09:51 AM
whitey94 whitey94 is offline
Cobra Make, Engine: 2004,FFR 302, carb. motor
Default Carb dry for cold starts
Hi guys!
I'm running a Carter HP electric fuel pump (100gph@7psi) with a Summit fuel regulator (4.5 to 9 psi) pumped into a Edelbrock 750 carb.
The problem I'm having with this set-up is there is not enough fuel in the carb for a couple of squirts for cold start-up. I added a bypass switch to the pump to fill the carb before starting. This is a pain! The regulator is adjusted down to minimum flow. If I turn it up the carb will flood out. I have adjusted the floats to Edelbrock specs. What is causing the carb to run dry? The engine (302) runs great at idle and down the road.
Any ideas?
Thanks!
