tfarhood,
That is an even better idea than mine! It would seem to be an easy fix. But will the tape wear out right away, or has yours survived alot of door opening and closing?
I also found my door was touching in the cowl area, so a little weatherstripping stopped that rattle too. This was fiberglass against fiberglass. I thought about using a Dremel tool to grind one or both sides, but used the weatherstripping instead.
It could be my door is really off in its adjustment. It looks OK, so I am not sure if the door was just molded a little bit off or it is truly that adjustment.
I will try your fix on the catch pin.
