Old 02-14-2005, 08:50 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default T5-Z to TKO-600 swap
In changing over from a 393W stroker to a 446 Dart small block in my CR 427 I'm also changing out the tranny from a T5Z ( which aside from the .67 fifth that I can't stand I've had fantastic luck with) to a TKO-600 for the extra strength and the .82 final gear ratio.
I read that a different bellhousing is needed and that the shifter location might be different, but am uncertain of any other changes that need to be made.
Can someone please tell me the difference in the bellhousings and any and all other changes that I will have to make to install this new tranny in place of the old one?..( driveshaft input spline?, shaft length?, crossmember?, shifter location?, input spline?, etc., etc.)
Thanks very much!
Regards to all,
Bill
