The breakdown above that is is a 1968 engine is correct. But as to wheather it is a 390, 428, or whatever, unless it is of the 385 series will require you measuring the bore and stroke to be certain.Since the engine has set this long, you should take it apart anyway so that is just something that will be easy to do. Another quick way to tell if it is an FE eingine is that most of them has the number 352 cast into the block up front. I am not sure what it means, but I have had that number on every FE engine I have owned from the 332 P.I. to the 427 tunnel port.
