RB:
Consider the items mentioned in the Thread as "not optional ", which is a good initial start in the registration process.
Obtain a copy of R-157 Composite Requirements from the CT DMV....a MUST read, all the requirements are mandatory including heat shields for the side exhaust. One source for the heat shields is Finish Line:
http://www.cobraaccessories.com/cata...t.php?cPath=50
If you wish, e-mail me your address and I will send you a copy of R-157
An unknown to me is the revised emissions testing as I was originally tested on the dyno with the previous contractor's centralized system
GOOD LUCK !!!!!
Don
