Old 02-16-2005, 02:12 PM
pneall's Avatar
pneall pneall is offline
Snkbte,
Unless Ian has changed his engine mount position you will need 20-25mm spacer bewteen rubbery engine mount and chassis so that the front pulley clears the steering rack. You have probably worked that out by now.
Make sure you put earth strap from engine mount to chassis or from some other part of engine to chassis. I went around engine mount as it was concenient.
Phil
