Thread: Cam Specs
Old 02-16-2005, 08:10 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks Don. I did notice that on the last two Comp rollers that I got both had edges that would cut with ease. I considered taking a jewelers file to them to break the edge, but had second thoughts and installed them as is. I'll be sure to clean this one up a bit before installing.
