Old 02-17-2005, 06:28 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
"Has anybody tried collecting the pipes into typical collectors and bolting together with gasket?"
Jeffko,
The problem with going to a typical collector type arrangement, at least on an ERA, is that each of the header tubes is a seperate piece. They need to be seperate in order to get them installed. If you connected them all to a single collector, you'd have one solid header that you'd never be able to install or remove.
Chris
