Old 02-18-2005, 05:05 PM
DAVID GAGNARD's Avatar
blykins;
I just got in my fuel lines today for my 650 Demon,half the fittings are blue and half red,not really pretty to me anyway.......Thinking about cleaning them with the oven cleaner trick........will it hurt anything to get the oven cleaner on the braided lines????? one end of the line is made onto the AN fitting (not removeable) but the other end can be removed??????? I'll be happy with just plane aluminum........
When using oven cleaner,what did you do,spray it on and wait how long,then wipe off with a scotch pad or rag and hose off or what?????????
I have used oven cleaner on other things such as wooden gun stocks and other wood products,works well,but never have used it on AN fitting.........
Also,when using AN fitting,do you use any kind of thread sealer, teflon tape or other sealer,or do you just screw them together without anything on the threads???????
Thanks;
David
DAVID GAGNARD
