Old 02-20-2005, 12:03 PM
Roscoe's Avatar
Roscoe Roscoe is offline
OK...OK...here is a source for the permatex equivilant
http://www.pegasusautoracing.com/Pro...asp?RecId=1029
Permatex Anaerobic Flange Sealant (Loctite 515) 50ml $13.95
Create flexible formed-in-place gaskets of any size and shape on close-fitting machined surfaces, gaskets that seal far more reliably than conventional pre-cut gaskets. Contains no solvent and will not shrink, drip or migrate. Does not cure until after confinement between mating surfaces and once cured it is impervious to attack by any conventional solvent, fuel or oil. May be sold in Permatex or Loctite packaging (same compound). 50 ml tube.
If you need more sources let me know........
Roscoe
Roscoe
