The adaptor only adds 10mm each side. The bolt on wheel centers have an aproximately 15-20mm thick raised section where they bolt to the hub. This is to make clearance between the wheel center and the brake calipers. With the knock off adaptor adding 10mm clearance you don't need this raised section so the back of the wheel center is machined almost flat.
Here's the clear powder coated centers:
