Old 02-21-2005, 07:08 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
I re read you post. Was it your intention to pull the drive out the top? That would be possible but not advisable for the reason the manual stated. Most improved (3/8") drives will not come out through the manifold anyway, the stock unit will but you'll lose the retainer clip into the oil pan, not a big deal but not the best way to deal with the drive, as you must use a stock size drive and it may migrate up, losing oil pressure (not likely, however possible)
The only right way to remove the drive is to remove the pan and the pump. I'd leave the old shaft in until you were planning on pulling the pump.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
