Old 02-24-2005, 06:18 AM
GOCATS GOCATS is offline
Cobra Make, Engine: B&B Manufacturing,351 SVO stroker from Bennett Racing
Thomas:
Part number is AEI-11101. I think they had it around $ 289. Check Jegs but I bet you the price will be very close. Hope you got some garden hoses hooked up to the carberator cuz that pump really puts out the pressure. I had put a fuel pressure regulator mounted to the back fire wall with at pressure guage on the front to help monitor fuel pressure. I keep it around 32-34 lbs even though the fuel injectors are 40lbs John Bennett said I could get away with that and not hurt the motor for most of the driving I do. But when its performance time I bump up the pressure makes things a little rich but better to rich than to lean Hope this helped.
J.A.
BTW: Tom how is you project coming?
