Old 02-24-2005, 08:22 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
3 problems I can think of. If the tires he's running are pretty wide he may be rubbing on the door latch cover. If you look in the rear wheel well you can see if that's where the tire is rubbing. Make sure he isn't rubbing on the outside on the wheel arch. You should be able to see on the tire if that's where it's rubbing. If it's bottoming out then the springs are the culprit. You can replace the rear springs with 225 lb Blue Coils. You may need to cut a couple of coils off for good ride height. If he wants coil overs I use Pro-Shocks 630SR with a 250lb spring. You will need to space the shocks out about an 1 1/2", I have the shocks and the spacers if he wants to buy from me. I also stock the blue coils.
Don
