The correct VIN will be stamped into the tops of both front inner fender panels, the drivers side should be visable with the naked eye. if no VIN is stamped there, then on the base of the windshield, just inside of the drivers side top of dash pad should be the actual VIN plate. The plate that is shown is not a valid serial number. if it was exported with that serial number in the past, and the UK DMV is using it as the actual VIN, then there are problems that your better off walking away from..........
Bill S.
