Thread: Seat removal
Old 02-27-2005, 07:36 AM
Rogers Rogers is offline
Cobra Make, Engine: Backdraft # 91, Black w/White stripes and Red Rookie's, 302 w/AFR 185's.
I've had the passenger seat out to adjust the parking brake..the nuts have the nylon inserts... 2 were hard to find...put a pair of vice grips on the nut you think is the one and turn the bolt from above...or reverse this process. The factory boys had to get those bolts in....they've got to be there...they also did'nt thread any frame rails to accept a bolt. The front left nut is almost even with the side pipe anchor bracket. All 4 nuts have 2 inch washers behind them....hard to miss. Go have another 6 pack and get started!
