Matt,
Here are the answers to your questions. Sorry about the delay in getting back to you.
- Carpet is included for the trunk.
- There are no interior door panels included. The inside of the door is gel coat and should be easy to paint.
- The included shifter is the lockout style. The lockout is non-functional but looks period correct.
- There is a 2 X 2 steel tube just below the body behind the cockpit that your shoulder belts will bolt directly to.
- The dash holes are pre cut using the S/C layout.
- The kit includes vinyl to cover the dash.
- The frame in the base kit is unpainted. We do offer a POR-15 coating option that includes the frame, rear end and all brackets.
- The quick jacks are powder coated black.
- All of the body holes are pre cut.
- The doors have metal backing plates for mounting the hinges and latches.
- We still need to update our frame pictures on the web site. The front x brace made from round tubing is in production. Our front suspension mount points have been significantly improved from the previous design. We have also dropped the drives foot box an additional 2" for increased leg room.
Hope this gives you the info you need. Let me know if you need anything else.
