03-01-2005, 08:06 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Jefco.... The roller cam requires a steel or bronze gear....not the cast iron gear that comes on the distributor when you first buy it. Ignorance and using the cast gear with a roller cam cost me a motor a few years back!..( Did I misread your post?)
