Old 03-02-2005, 03:37 PM
Brent Mills Replace the pressure plate and disc. The fluid will soften the material of the disc and it could chunk and fly apart. Flywheel may have the oil in it to. Clean it very go and let dry. If you see little oil spots on the surface after the cleaning you will need to get the flywheel cut. The oil will heat and go back into the disc on the clutch and the same problem will happen with the disc material going soft. I metalic disc may be OK if the oil is burnt off. The pad material is harder but the fluid may leave spots on the flywheel and cause slipping and burning spots. Do it one time and save the pain of having to pull the trans twice. See what it is to cut the flywheel. $30-40 dollars, get a new surface on the flywheel. Rick Lake
