Old 03-02-2005, 04:28 PM
pneall's Avatar
pneall pneall is offline
Les,
I might be wrong (often am) but my idea with the wire was as an indicator only. I put the wire on slack , if it gets tight it means there is movement?? The wire is not actually meant to stop turning. Have I got it all wrong.
More than happy to learn.
Les , you are going to Winton?
Mando, the orange pipe is a 4" duct connecting cone shaped k&N filter to TB. The filter is mounted in front of radiator. This is only temporary. I plan to make up inlet pipe in aluminium and shield the filter as it gets dirty real fast in its curent position.
If (when?) I go with PD blower I will probably run two x 4" filters out front with alumium ducting to the TB.
Phil
