Brent Mills Brent I don't know what knucklehead you talked to at Mcloed, I sure it was not Red. That brake fluid will absorb into that disc, IT WILL NOT EVAPORATE!! I which I had a camera to send you a picture of a zoom clutch that came from my jeep. Brake fluid leaked out the hydro bearing I had into the clutch assembly. R&R clutch clean the fluid out and thought the same. As along as it is clean, it's OK. The disc blew apart 3 weeks later. I didn't have a Lakewood shield in the jeep, lucky all the parts went out the bottom of the bell housing. Should have lost a leg, on trying to do what they told you. I now have lakewood schatter shields on any car with a clutch. That disc does alot when they blow up, pieces fly every where. Put new parts in the car and not worry about trying to save $100.00. Rick Lake
