427 4V TUNNEL PORT INTAKE-New Old Stock-
Brand new in the factory box. This is a SINGLE 4V intake.C8AX-9424-B.
This has not been cut, drilled, welded, or modified in any way.
$1000.00
ORIGINAL FORD 427 Dual 4 AIR CLEANER
Factory Original Ford Dual 4 BBL Air Cleaner. Came off a late 60s Torino. Excellent Condition.
$250.00
FORD 427 SIDEWINDER INTAKE MANIFOLD
Designed for a 427 Medium Riser Engine. Number is C6AE-9425-K. It will fit a Low Riser and a Medium Riser, and the 428 CJ heads on any FE. Dual Plane design should give maximum low end power and the offset carb pad equalizies runner lengths for maximum top end power.
$750.00
427 SIDE OILER SERVICE BLOCK-New Old Stock
The block was in cosmoline and in box. .Correct pistons have been ordered , ready for completion. It is sitting at George Anderson's at Gesford Machine in Hastings Nebraska. It was cleaned and magnafluxed and sonic checked. No welds, no repairs. If interested, I will arrange for George to explain the block in machinist terms. Please do not call him asking about this block, unless there is a serious interest and we have agreed on the terms. Then I will arrange him to talk to you. There is some detail on this block at the following address.
http://www.gessford.com/quotes/images/Turk427no3.htm
Block was $5500.00 You have to pay for the machine work and the pistons that are already ordered for it to buy it.
Call George and talk to him about Details.
427 TUNNEL PORT HEADS-Excellent condition.
C70E-6090-K
Heads are lightly ported and polished.
$2000.00
MATCHING INTAKE FOR ABOVE TUNNEL PORT HEADS- Excellent-
C70E-9424-A
2X4 Tunnel Port Intake.
$1000.00
