  #29 (permalink)
Old 03-04-2005, 04:47 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally posted by Excaliber
...The intake is a single plane 2X4 with full blown "race only" center squirter 660 Holleys. The engine was built "loose", I found out when I took it down. All clearances were at max. Like .005 on the piston clearance when .003 or so is normal...
Excaliber, do the center squirters have power valves? They didn't come with them, but you can put the front plate from a vacuum-secondary 600 Holley in them with it's power valve (used ones work fine...no moving parts). Jet the 660s down 6-8 sizes, and you've got a streetable carb. Without the power valves, they run waaay too rich at idle.
Also, .005 clearance is pretty standard if the pistons are forged. Cast pistons will run tighter clearance, but you don't want them in a performance motor.
Just some food for thought...oh, and I'll bet that baby screamed!
