Jag hubs are out, now what?
Both rear wheels where a bit loose. When I took the tires off, the hub would slide slightly back and forth on the shaft. So, I pulled the hub. The spacer looks slightly abused but the hub/bearings looks fine. Do the spacers tend to get beat flat? After all, they are nothing but brass! Any thing else I should check out/do?
Thanks
Rick
