Old 03-05-2005, 04:50 PM
rdorman Rick get the jag book. It shows you a step by step how to check the bearings and end play. You want .000 to .002 play. You can measure the end play on the movement and then just just add the differents to the shaft. Retork the axle nut put the wheel on and check the play of the wheel assembly. You may have to go to a Jag dealer and get a pack of .010 shims. Have you been greasing the hub housing? A high temp sythetic grease is what you want. When done right the end play should last 20,000 miles before a check is needed. If you are wearing the shim out, it is too loose in the housing and has been that way for a while. Rick Lake
