Originally posted by bomelia
can you park under it?
Yes, if your ceiling clearance permits.
Each lift is only slightly different, but generally, they all can raise about 63+".
Here's one spec:
Description SS7000 SS7000 XLT
A Overall Width 111" ______________ 111"
B Drive Thru Clearance _____ 98" _ 98"
C Distance Between Foot Pads _ 87" _________ 87"
D Distance Between Tracks _________ 38" _____ 38"
E Length Of Ramp ____________________ 36" _______________ 36"
F Length Of Tracks ___________ 164" ___ 184"
G Track Outside Width ______ 76" _______ 76"
H Track Width ___________ 19" __________ 19"
I Foot Pad Dimensions 12" x 12" 12" x 12"
J Overall Length (without ramps) 170" _____________ 190"
K Clearance Under Ramp (on lock) 68" 78"
L Overall Height ___________________ 82" ______________ 92"
M Distance Between Posts ___ 155" 175"
* Lifting Capacity __________ 7000 lbs. ________ 7000 lbs.
* Pump Motor 110 V or 220V. 110 V or 220V
Originally posted by rblong
Anyone had any history with the American-Product lifts? Done any comparisons?
We're trying to compare them right now, see previous post.
Our primary concern at this point is the strength of the welds.
Originally posted by misfit41
I have 9 foot ceiling in my shop,,can I park my cobra and still have room for another car ?? if so I am interested,,thanks,T
9' = 108" ... 6" ramp height = 102" /2 (assuming same car height) = 51"
but where's the nearest stop for the lift?
if it's every 4-6 inches, you may have to figure that in.
now, do you have an overhead garage door opener?
all these factors need to be considered
