Thread: Rear end gears
Old 03-08-2005, 09:42 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Both statements above are good. But if you change the rear end make sure you look at your axels and get the correct spline count.
I am running 3:27s in my car and love them, but I have quite a bit more power and torque than you do. Only problem I have is I picked the wrong transmission split for 5th gear. I went with the .6 and should have gotten the .8 as all my 5th is good for is crusing down the freeway. I can't break through that wall of air in 5th to even get close to my power band with my split, as it effectively brings my gear ratio to 2:10s, which as stated above are Bonneville type high speed gears. I tach 1900 RPM at 70 in 5th. Crap, if I could get to my power band in 5th I would be over 200 MPH and that wall of air would blow every huose within 50 feet of the road over.
But I also have no problem burning both tires in any gear except 5th. I don't do much of that though and then mostly by accident.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
