Old 03-08-2005, 06:35 PM
byron w byron w is offline
Cobra Make, Engine: shellvalley 428 ford
blykins, the web site does not have the chart like the catalog does but here is the of two qa 1 shocks. if you have a fax i will fax the entire chart.
byron w
721395-200 QA1 COILOVER KIT, 200 LB.
PR $369.95
721395-300 QA1 COILOVER KIT, 300 LB.
PR $369.95
721395-325 QA1 COILOVER KIT, 325 LB.
PR $369.95
721395-375 QA1 COILOVER KIT, 375 LB.
PR $369.95
721395-400 QA1 COILOVER KIT, 400 LB.
PR $369.95
721395-500 QA1 COILOVER KIT, 500 LB.
PR $369.95
7213955 SHOCK & COILOVER KIT ONLY - NO SPRING
10 3/4" - 11 1/4" @ ride height. 12 3/4" ext. 9 1/2" comp. Uses 8" spring.
EA $154.95
SUGGESTIONS
25508-200 CARRERA SPRING 8" COILOVER, 200 LB.
EA $49.95
25508-300 CARRERA SPRING 8" COILOVER, 300 LB.
EA $49.95
25508-325 CARRERA SPRING 8" COILOVER, 325 LB.
EA $49.95
25508-375 CARRERA SPRING 8" COILOVER, 375 LB.
EA $49.95
25508-400 CARRERA SPRING 8" COILOVER, 400 LB.
EA $49.95
25508-500 CARRERA SPRING 8" COILOVER, 500 LB.
EA $49.95
721485-115 QA1 COILOVER KIT, 115 LB.
PR $369.95
721485-140 QA1 COILOVER KIT, 140 LB.
PR $369.95
721485-185 QA1 COILOVER KIT, 185 LB.
PR $369.95
721485-225 QA1 COILOVER KIT, 225 LB.
PR $369.95
721485-300 QA1 COILOVER KIT, 300 LB.
PR $369.95
721485-450 QA1 COILOVER KIT, 450 LB.
PR $369.95
7214855 SHOCK & COILOVER KIT ONLY - NO SPRING
11 3/4" - 12 1/4" @ ride height. 14" ext. 10 1/8" comp. Uses 10" spring.
EA $154.95
Website is:
www.speedwaymotors.com
