Old 03-09-2005, 10:24 AM
SGC48 SGC48 is offline
I heard that Tremec was producing a shortened input shaft but had no confirmation until now, thnaks Dreamer. I don'y know the cost, but I would think that the spacer is an easier solution. However, if you are running a solid rear axle, that 3/4" might make the drive shaft too short so your only real option is the shortened input shaft. Now if you have IRS there is no issue with the drive shaft length.
-SGC
