Coleman I sent you a PM concerning lifts.. I allready have one.. works fine for me and Boyd.. I also got a few extras.. rolling bridge hydraulic jack, a must if you can afford it..lets you lift tires off of ramps to do brake work, etc. rolling
oil drain pan..drip pans..... car sits a little to low for bridge jack to roll all the way from front to back of car.. so when I need to use it I just place a 2x8 under rear wheels when I pull car onto lift. My friend has a backyard buddy and there is no place for the rolling jack to sit as it has no guides welded onto ramps, just the ramps only.. he has to order his from them at almost twice the cost..my lifting cross beams ride inside the columns, with a double safety air lock system, his ride on the outside..my lift has 2 hydraulic lins to cylinder, his has only one, by the way I paid a lot less for mine also, if you want I can post a picture and if you buy the same brand I can give you some pointers on putting it togeather as I did my own..
