I had a 63 1/2 Galaxie with 2x4v and a C6 with The kick down hooked up. (Not factory of course) I used the 67 Mustang lever on trans with the short cable from Mustang. Had to make a bracket off of the accelator pivot at the firewall. Now your saying to yourself how does that help me I have an Accelerator cable. I don't know but I thought that it might help get your wheel turning. You could probably take a cable from your linkage down to your kick down lever on the trans and make a couple of brackets. Look at the 67Mustang set up. You don't have to use the kickdown rod on the carb. Just have enough slack in the cable to pull trans into passing gear at full throttle.
Tony
