Old 03-11-2005, 07:41 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
You might also try retarding the timing a couple of degrees. Last but not least, another trick that might allow you to "live with it" is to put the car in neutral and release the clutch before turning the key off. The extra drag created by gearbox will often result in the car shutting down without dieseling.
Chris
