Yeah,
I'd probably buy a TKO, and cut up the floor boards, tunnel to make it fit. ? shifter, ? driveshaft, ? speedometer modifications, ? anything else
You could have David Kee rebuild the toploader, with wide ratio parts , ? $800-1000, and install new rear gears ? about $400 -500. You wouldn't have to buy a new shifter either, speedometer hook up OK, drive shaft the same, etc.
It's your car.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
