Old 03-12-2005, 10:57 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Scott,
If you do have a bad rgulator you should be able to get one at any good parts store. An easy way to check if the alternator is putting out is just take a volt meter and put it across the battery terminals and rev the engine up. It should read around 13/15 volts. I use a voltmeter in the dash and mine reads 14 volts.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
