I still have to pull the sender. Faria says that it is most likely a 230-33 ohm unit. Jegs has them for $75, I might be able to get them a little cheaper ($65 or so). I think they will work because they are meant for an 8 1/2" deep tank, which ours is. NO fiddling with adjustments. It looks like it has a standard bung on it, so we will see. May try to pull the sender later this week and put a multimeter on it.
Tom
