Thread: Still Smoking
Old 03-12-2005, 09:23 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
REtorque the intake just to be safe. It sounds like a gasket head or intake. When you retorqued the headbolts did you apply sealer on the bottom head bolts? I had a coolant leak due to a intake leak. the guy that built my engine advised not to retorque the heads due to the type of head gasket and sealer on the bolts. I was told not to over torque the intake on aluminum heads because it will cause a head gasket leak. Reg is a class act and its great you have a warranty. Don't over torque any bolts.
You may have to put new gaskets on it (intake and head) .
Later Dennis
