How about you try White Lube assembly grease for transmissions?? It is the CORRECT stuff to use for trans assembly and can be bought at most local parts stores. Comes in a white tube and is not expensive.
Not a big fan of wheel bearing grease as it will not break down in the newer trans that take a 10w/AT fluid.
Just a thought from a builder in Fla.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
