Don't pressure test it before you pull the plugs. The last thing you want to do is fill a cylinder with water. After you pull the plugs and spin it over to see if anything comes out would be a better time to test it. If you forget and turn it over with a cylinder full of water you can bend a rod. Not good or fun.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
