Retail for the TWM injection is around $4,200.00. We used a FAST computer (2,400.00) -10 braided stainless to two -8 BS feeds and -8 BS return (lines about 500.00). I installed a 14 cubic inch vacuum resevoir between the TWM resevoir and the MAP sensor to smooth out the vacuum pulse and make it more readable by the MAP sensor. We chose the cam based on the injection as well as CU. IN., head flow, end hp/ torque needs, etc. I believe that no matter the cam grind, the injection will work better than carburation due to the computer. It's the best of 2 worlds, the look of Webers, and the performance and reliability of EFI.
Al W.
