Old 03-15-2005, 06:58 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Scotty,
The amp gauge will normally run right at the center unless the battery is low and then is will show on the + or charge side until it gets the battery back to normal. The dropping when you fist turn lights and accessories on is normal as you are adding draw to the battery and the alternator has to compensate for it. So yours is working correctly now. Good luck.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
