Old 03-15-2005, 09:23 AM
Slither's Avatar
Slither Slither is offline
Cobra Make, Engine: Alum bodied CSX4266, fuel injected alloy 472, 663 hp Engine built by Dralle. Suspension by Tom Barnard
Michael, the Edelbrock heads were modified quite a bit, but the manifold seems to have sealed real well. No problems. I went with the 58mm models. Check out my picture gallery, I added an overhead shot of the TWM setup. I did not go with the air box because I didn't like the way it looked. If you use that air box, you would have to modify the opening on the underside of your hood. I am looking in to a set of push on foam filters. As for the audio file, I'll work on it.
Bill
Don't underestimate the predictability of stupid!
