Old 03-15-2005, 02:08 PM
blykins blykins is offline
Default Dipstick question...
Would a regular dipstick that mounts in the front cover (SBF) sit down in the pan the same distance, no matter what pan is used? So if you use that dipstick in a 5-quart stock fox-body pan and it reads 5 quarts....then if you change pans to say a Canton T-sump pan...it would still read 5 quarts, right? Because it will extend the same distance into the front cover....no matter what pan it is....
So if that dipstick read full (5 qts) on a Canton pan, it would be common sense to say it's not showing all that's in the pan, right? The pan sump is out of reach of the dipstick, correct?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
