Old 03-15-2005, 05:51 PM
GeorgiaSnake's Avatar
GeorgiaSnake GeorgiaSnake is offline
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Default Another Atlanta FIA For Sale
It's time for another project so my Unique FIA is For Sale
Well sorted (2,600 miles) Unique FIA (ID#2899420, manufactured in 2003) powered by a SA 396 stroker running through a wide ratio toploader to a 3:31 limited slip Jaguar differential. Team III 16” wheels (8” fronts, 10” rears), B.F. Goodrich T/A’s (245/50/16 fronts, 265/50/16 rears). PPG Mercedes Brilliant Silver. The car is registered in Georgia as a 1964 Cobra FIA. Build pictures and receipts are available. See my Gallery for pictures.
$41,000
Unique Deluxe Pallet with following Options
Tonneau Cover
Aluminum Foot Box Heat Shields with Thermite Insulation
Battery Disconnect
Driveshaft Safety Loop
Moroso Remote Oil Filter
Hurst Indy Shifter (relocates shifter to proper FIA position)
5 Point Harness (both sides)
Heater (no defroster cuts – have the aluminum vent covers)
3 Raydyot Mirrors
Seat Track (driver’s side)
Instrument Upgrade (Stewart – Warner large face)
Wind Wings / Sun Visors
15” Leather Steering Wheel
Moroso Inline Filler
Differential Cross Brace
Oil Cooler w/ Stainless Hoses
Canton Expansion Tank
Added
Optima Battery
16” Puller Fan (twin pushers included but not mounted)
Aluminum Shrouding for Oil Cooler / Radiator
MSD Ignition
Indoor Car Cover
Engine Build Sheet
351 W Block – E3AE-6015-18
Scat #8160 3.850” Steel Stroker w One Piece Seal
Ford D60E Forged Rods w ARP Bolts
Engine Tech – Hypereutectic Pistons 9.8:1 Compression
Hastings Molly Rings
Engine Tech Bearings
Elgin E961P Solid Lifter Cam (cam card available)
Melling High Volume Oil Pump
Canton 8 Qt. 15-660 Pan
Edelbrock Performer RPM Aluminum Fully Ported and Polished Heads
Edelbrock Performer RPM Port Matched Manifold
Motorsports Roller Rockers
Motorsports 8.5” Heat Treated Pushrods
Holly 3310 750 CFM with Choke Removed and Quick Change Spring Kit (assorted springs and jets included)
Centrifugal Advance Electronic Distributor (looks like original style)
Carter High Volume Mechanical Fuel Pump
Aluminum High VolumeWater Pump
March Pulleys
Aluminum Flywheel
Ram 11” Power Grip Street Strip Clutch (new less than 200 miles)
Lakewood Blow Proof Bellhousing
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
