Old 03-17-2005, 05:31 PM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Engine weights vary dependant on how they are built and what castings are used . For example a factory iron 460 block weighs from 175 to 220 lbs dependant on casting and year, and 351 blocks range from about 135 to 165 for a early truck block. The weight of crankshafts vary too, but the % of weight lost favors the aftermarket big blocks crank with the Chevy rod setup, as apposed to it's stock weight. Most (not all) small block stroaker cranks weigh the same as stock or even a bit more, and that includes most of the small journal stuff out there.
The upside and the downside to this is All Ford V8's can be built normal or lighter if attention is directed to factory castings, etc, if you were to work at weight as a objective.
As for most of these Cobra motors, (using factory blocks and aftermarket stuff) I tell people that most times the engines go up about 50lbs for each step/up in each block casting class.
So 302 combos come in at about 350 lbs, plus or minus. 351 combos at roughly 400, FE's at roughly 450 total and 385's a tiny bit over 500 most times. Bet that's why nobody wants to quote you engine weights? You see, they know better.
My 385, a 30 over 460 with a 4.5 inch stroaker crank, w/Chev journals and Blue Thunder heads came in at 545lbs with a few accessorys on for example.
My own opinion is the difference in weight between even a 302 and a built 460 is really small in a ill handling Cobra. Other than in drag racing I would NOT be racing ANY Cobra with a iron block!
Cobrashock
Ron Shockley
