Old 03-20-2005, 03:30 PM
Rick Parker I have the same book John talked about and he is right. You need a spring compressor with the spacer to get on. You can start with a 1/2" spacer and see how that works. You have adjustable sway bar, this makes the car handle. The spring holds the wieght. I went with a soft spring and tighen the sway bar for cornering. As I said you don't want the ride of a tractor with your car, you need the tires to have full contact patch to the street or track. Bigger, stronger, larger, or heavier don't always work better. Car only wieghts 2500 lbs. Rick Lake
