Sounds more like a master going bad. Are you losing any fluid? Check around the dust seals on the master and slave for any dampness. Pull the boots back a bit to see if any fluid leaks out. If it does you have your problem.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
