Cutting Rotors
The previous reply is absolutely correct.
There are however two types of lathes used to cut rotors. The more common one is a stand alone lathe designed specifically for cutting rotors, and there is also an on-the-car brake lathe that cuts the rotors while they are still mounted on the vehicle.
Regardles of what type is used, the process is still basically the same.
