Old 03-22-2005, 05:25 AM
The Dreamer The Dreamer is offline
Cobra Make, Engine: KMP329 w/KC489 Shelby
My slave lines up initially, but as the fork pivots, the end moves in an arc. I think I'm getting binding as the fork travels in the arc. I have a Lakewood bellhousing, so I'm using the same pivot as the big block forks use, only I have the fork for a Tremec.
My set up is a little different than most Kirkhams because I'm using the TKO600 and from what I can tell, I'm one of the first to actually get it running. My pressure plate (12 in) is different than the Toploader big input pressure plates and that may affect how much travel is needed to release the clutch. I know I'm close, but as the clutch gets heat into it, shifts become harder.
I'm first going to try to find a .75 Lockheed-Wagner slave and if I can't find a smaller bore slave, I will swap out the master for a CNC .875 bore.
