Old 03-22-2005, 04:06 PM
tpiini tpiini is offline
Originally posted by The Dreamer
I'm getting the same symptoms and it is because the clutch is barely releasing. As the clutch heats up, it is harder for the clutch to release. The clutch is not touching the flywheel enough to lock, it just slips. I need more travel on my slave cylinder to get a full release.
In my case, I ended up going to a 7/8" master cylinder. That moved the slave full-stroke, but the 1 1/8" of stroke wasn't enough. At the advice of the manufacturer, CNC Brakes, I removed the return spring from the slave cylinder and put a return spring on the fork. Removing that spring gave me about another 3/8" of slave cylinder stroke. THAT fixed my problem.
So if you can get a helper to push your pedal down while you're under the car, you can see if you are stroking the cylinder fully or just bottoming it out at full-stroke. If you're bottoming it out, take out the spring. If it's just not moving full-stroke, go with the larger master cylinder.
Hope this helps you,
Tom
