What pedals are you using? This is exactly the same problem I had. If the clevis yoke is attached at the wrong pivot point on the pedal you will not get enough travel in the master cylinder. The billet pedals have a pair of holes so they can use as either brake or clutch. It’s been a couple of weeks since I looked at them, I believe it needs to be mounted on the top hole. I assume the cover over the pedals has been removed. Press the pedal and look at the angle of the rod in the master cylinder. If its not straight thats the problem. I was only getting 5/8" travel on the slave side before I discovered this.
Rob
